zooming993
- Joined
- Jul 3, 2011
- Messages
- 10
- Tractor
- John Deere 755
I own a JD 755 tractor with about 460 hours on it. I bought the tractor earlier this year so I haven't really used it much, maybe 10hrs. I have a FEL installed and occasionally pull a 48 brush mower. After purchasing the tractor I proceeded to change all the oils (crankcase & Hydraulic) and filters (oil, hydraulic & fuel). Now to the problem I'm experiencing. The tractor starts up with no problem and runs fine on flat land however, when I attempt to climb a hill even a small one the engine bogs down and ultimately dies if I don't lift up on the forward pedal. I first thought I had a hydrostatic transmission problem because when I changed the hydraulic fluid I did not use the JD Hydra Gard fluid, I used Tractor Supply premium brand. Thinking this was the problem I drained the fluid and replaced it with the JD fluid but the problem still exists. Thinking it wasn't the hydraulic fluid causing the problem I started to look into the possibility of a fuel delivery problem. With this in mind I took the tractor for a spin around the property and while doing so the oil light flickered on and off briefly so I turned off the engine. When I got off the tractor I noticed a few drops of oil dripping from the bottom of the tractor so I pulled it into the garage to investigate further. It turns out the oil came from the overflow tube coming from the valve cover. When I went to check the oil level I was surprised to find the oil level well above the full mark, my first thought was I blew a head gasket but there was no evidence of water and the radiator was still full. Now I'm really scratching my head trying to figure out what was going on. I know I didn't put to much oil in when I changed the oil because I still have some left in the 1 gallon container. Then someone told me it could be diesel fuel so I'm now trying figure out if it is? I'm leaning towards it being fuel because I know it's not water, could it be hydraulic fluid? I tried to see if I could smell diesel fuel on the dip stick but I couldn't tell.
Thanks for your help
