JD 755 Fuel filter fittings came off
   / JD 755 Fuel filter fittings came off #1
lostsixshovels
northern california
John Deere 755, and Kubota U10
I have a John Deere 755, while working I could smell diesel and notice liquid leaking from the engine compartment. I shut it down and readied the extingusher, but only smoke came out. I supposed the fuel hose broke, but no, the fitting came out of the filter housing. It appears to be a press fit, not good for fuel under pressure. So I pushed it back in and put a hose clamp around it and the filter to hold it in ( it is an ell so that pulled it in). So a few weeks later the tractor starts, but is sputtering, I shut it down and find the output side fitting is now off, and dumping fuel. this is a straight fitting and cannot be wrapped up. I pushed it back in and it won't come out now, but my trust in the integrity is shot. I would replace the bowl assy but don't trust a new press fit one. Is there a good after market bowl/filter available? Is this a common problem?
   / JD 755 Fuel filter fittings came off #2
There are dozens of aftermarket filters available. I'd start with a marine outfit, a lot of small diesels similar to the tractors are used in smaller boats. A flat bracket and the fittings, you should be good to go.
2007 Freightliner Columbia 120 - Class 8, 6x4, Mercedes MBE4000 Diesel (A52748)
2007 Freightliner...
2011 Chevrolet Impala Sedan (A51694)
2011 Chevrolet...
2016 CHEVROLET 2500 TRUCK (A51247)
2016 CHEVROLET...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A52141)
2006 CHEVROLET...
RYOBI 18V BRUSHLESS ELECTRIC 20" PUSH MOWRE (A51248)
RYOBI 18V...
2009 ARROW BOARD MODEL - 9069 (A51247)
2009 ARROW BOARD...
