Good evening,
well i finally bought a box blade and reserved myself some time to work with my project tractor.........i am the one who sturggled with a list of issues, most notably low oil pressure and non-working mfwd. Well, those are now successfully corrected thanks in part to advice from you all. i tried to use my new box today but found that the 3 pt takes an extreme amount of time to drop, but only when tractor is warmed up well. Works great when cold. Takes about 2 minutes to drop when hot.....?
i have turned the spigot in/out several times and it does not improve. i was hoping that would be it, but no luck..
i did change hydraulic oil and filter and used jd oil and filter. Dealer sold me hy-gard regular, stating that regular and low vis were both approved and regular was about $10 cheaper.
Does this sound like an oil quality issue or possibly something else? I have had 3pt hitches that would not go up, but never one that would not drop?
BTW - this is the first i have used the tractor so i have no clue if it did the same thing before i changed oil and filter..
Any thoughts as to why the 3 pt hitch will not drop when hot?
Thank you,
David in sunny SC
Thank you,
David in sunny SC
