JD 750 won't start.
   / JD 750 won't start. #1
JoeJChin
Archbald Pa
JD 750
Hi all.
Need help with a starting problem ..
I picked up a JD 750 (1986 vintage) a few months ago .
I wasn't able to run it much until i got new tires for it and fixed the starter on it .
When i bought it , it guy i got it from ,said it was a little hard starting , but ran fine once started.
It took maybe a 1/2 second shot of ether , down the intake, while cranking it and it would fire right up .
Even after sitting for a month ,outside in 20 degree weather , all it took was a quick shot of ether and it started like it had been run a half hour ago .
Now comes the problem .
I ran it for about 2 hours pushing snow , and it ran fine.
I shut it off , to go get some more fuel , before starting on my son's house.
Came back within a half hour of running it , put in 5 gal of fuel, and it wouldn't start back up .
Not evem with a shot of ether,
I went thru the owners manual, and bled all the lines , fuel filter, injection pump etc. even though it wasn't run out of fuel.
I got good fuel flow up to the injection pump, and a little bit of flow up at the injectors .........not sure if it was what it should be or not .
I don't see much smoke comming out of the stack while cranking it , so i don't think it is getting any fuel .
Is there anything in the injection pump that could "STICK" ??? and keep it from pumping fuel.????
Is it likely that the pump could just GO BAD , after it was shut off.
Like it said , it ran fine when i was using it and when i backed it in the drive way to shut it off.
I would hate to have to buy an injection pump for it , especially if it turned out that was not the problem
any suggestions welcome ,
thanks in advance
Joe
1992 SHOP MADE CHASSIS TRAILER (A53843)
1992 SHOP MADE...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
2015 MACK CHU (PINNACLE) TRI AXLE(INOPERABLE) (A53843)
2015 MACK CHU...
Genie GTH-644 (A50490)
2015 MACK CXU613 MID-ROOF SLEEPER (A53843)
2015 MACK CXU613...
2013 Jeep Patriot Sport 4WD SUV (A53424)
2013 Jeep Patriot...
