JD 750 Tachometer whacky
/ JD 750 Tachometer whacky #1
mfrost
CA
JD 750
My tach went bonkers today then it started making noise in the dash. Think it is the cable. Will check it out tomorrow. Any any ideas of what it could be. If it a cable is there any place I can get one withut going to John Deere.:confused:
/ JD 750 Tachometer whacky #2
Try NAPA auto parts. They may be able to make one to fit. Robertson Fleet Service in Dallas used to make them, not sure if they have a place close to where you are. Look under speedometers in the yellow pages for a place near you.
/ JD 750 Tachometer whacky #3
It likely is the cable going bad.
A cable for my JD 850 is only around $16.50 through the Deere dealer.
I doubt you will save any $$ getting a cable made up elsewhere.
The tach is as quite as a mouse now. :D Cable was fine but cleaned and lubed it. The tack input shaft bushing was dry. :eek: A little LPS did the job.
It was kinda of a pain getting the gauge out and back in but no $$$$ spent.;)
2012 Chaparral Sunesta Boat with 22ft. T/A Continental Boat Trailer (A61569)
2012 Chaparral...
TEST YOUR BID BUTTON! (A62129)
TEST YOUR BID...
2019 GENIE GS-1930 ELECTRIC SCISSOR LIFT (A62129)
2019 GENIE GS-1930...
2011 Infiniti QX56 Multipurpose Vehicle (MPV), VIN # JN8AZ2NEXB9001685 (A61165)
2011 Infiniti QX56...
2017 Bobcat E55 (A60462)
2017 Bobcat E55...
3ft. Wooden Native American Statue (A61569)
3ft. Wooden Native...
