JD 7410 Hydraulics overheating
/ JD 7410 Hydraulics overheating #1
Taco78
Muscatine, Iowa
JD 7410
My JD 7410 hydraulics overheating warning light comes on after running PTO while mowing hay. When this happens the transmission hesitates to go into forward position but will go immediately into reverse like normal. Any ideas as to what is wrong?
/ JD 7410 Hydraulics overheating #2
Are SCV levers returning to neutral once cylinder is at desired location??
Yes. You can mow for about 30 minutes before the light comes on and then if you stop, disengage the PTO, and put in park, it will cool off enough for light to go off and may run 10 minutes or less before the light comes on again.
/ JD 7410 Hydraulics overheating #5
Is this what you have?
JD 7410
Hydraulics:
Type: closed center pressure flow compensated (PFC)
Capacity: 15 gal [56.8 L] (2WD)
17 gal [64.3 L] (4WD)
16 gal [60.6 L] (2WD creeper)
18 gal [68.1 L] (4WD creeper)
Pressure: 2900 psi [200.0 bar]
Valves: 2 to 4
Pump flow: 26 gpm [98.4 lpm]
38 gpm [143.8 lpm] (optional)
Total flow: 16 gpm [60.6 lpm]
/ JD 7410 Hydraulics overheating #6
Taco78
Have you checked hyd temp with a laser thermometer? It's possible you have a bad sensor.
2022 Chevrolet 1500 Silverado Crew Cab 4X4 Pick-Up Truck (A59230)
2022 Chevrolet...
2008 Mercury 25HP 3-Cylinder Boat Motor (A59231)
2008 Mercury 25HP...
2015 DODGE DURANGO RT SUV (A59575)
2015 DODGE DURANGO...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A55315)
2012 UNVERFERTH...
Tandem Axle Rear Truck Frame (A59228)
Tandem Axle Rear...
2008 Mercury Milan Sedan (A59231)
2008 Mercury Milan...
