Planters JD 71 Planter Questions
   / JD 71 Planter Questions #1
N1ST
Enfield, CT
Kubota B7800
How do you get the discs off? I took the center bolt off and tried to pry it from the inside with a long screw driver... ended up breaking the cast tail piece off.
How do you get the wheel axle off? I took the set screw out and pounded the shaft from inside the chain box... no joy.
The parts diagram for the idler assembly shows 2 6010-377 CHAIN SPROCKET, 7 TOOTH gears, but on mine one has much smaller teeth. Are these 2 gears really the same?
Anyone bought any new gears? My 14 tooth has rounded teeth, and I'm missing the 11 tooth. How much does JD charge?
Can a new chain be bought for a bicycle chart?
2008 JLG 450AJ SERIES II TELESCOPIC MANLIFT (A51242)
2008 JLG 450AJ...
Wolverine Quick Attach Hydro Slide Pallet Forks (A50514)
Wolverine Quick...
Toro ProCore 864 Series Turf Aerator Tractor Attachment (A51691)
Toro ProCore 864...
SHOP MADE  MANIFOLD TRAILER (A50854)
SHOP MADE...
(30) 9' Pipe Fence Posts (A50515)
(30) 9' Pipe Fence...
KUBOTA L2650 TRACTOR (A51243)
KUBOTA L2650...
