Planters jd 71 planter pumpkin seed plate
   / jd 71 planter pumpkin seed plate #1
luckyme2010
Bronze Member
mobile alabama
mahindra5530 4x4
hey yall i have a one row 71 planter and im wantin to plant pumpkins next summer for the fall i cannot find a pumpkin seed plate anywhere even the jd dealerships either wont help or knows nothing about them i saw some on ebay a few times but not any since ive really been looking for them to buy what about a soybean plate can that be altered to work with large pumpkin seeds or if somebody has a pumpkin seed plate to sale i want it thanks yall
   / jd 71 planter pumpkin seed plate #2
I would think you could match a bean or corn plate to plant pumkins. Do you have any idea about the size of the seeds you are going to plant. You can purchase blank plates and make your pockets/cells. Blank plates can be had from Lincoln Ag products. Lincoln also sell ready mades if you can match your seed size. I saw pumkin plates on E-bay last planting season, but they were very expensive.
Lincoln Ag Products
well im new at the planter thing me and daddy always done it "the way that works best" and after 5 acres of corn last year im done with that way i called lincoln ag a few times last week but never got a answer ill try em again tomorrow ive been lookin at a soybean plate to use maybe cut some teeth and weld some up im not sure how to size a seed i know the pumpkin seeds ill be planting are about half inch to 3/4 inch long for large pumpkins and flat so thats got me wondering will the seed get trapped under the plate and just grind instead of being picked up whats the deal with a blank plate you just drill out the size groove you need?
   / jd 71 planter pumpkin seed plate #4
I have a XL spreadsheet that I have compiled that gives the dimensions of the cells in plates. I can send that to you on E-Mail. May be able to do it here, but I don't know how. Inquire at this address if you want the XL sheet.
jbooth1013@mchsi.com
I don't think you will have a problem with pumkin seeds going under the plate, but due to thickness of the plate it may plant 2 or 3 seeds at a time. Seems that was the way we planted the pumkins anyway.
In looking at my XL sheet and you seed size description, I would say the cast iron 1255 soybean plate might work. The cell dimensions on it are .781" long X .421" wide and .312" thick. The 2527 cast iron has same dimensions, but is .406" thick. The 1255 plate is pretty common and shows up on E-Bay regularly. I could probably sell you either one if you are not successful elsewhere. Quite a few corn plates that may have some possibilities too.
thanks J i shot you a email heavy250@aol.com i wouldnt mind buying several plates im sure ill use em for some type of seed i only have the 3 that came with it and i know ones a medium corn plate ones for sunflower the other im not sure i read somewhere to about the different cell and changing the gear ratio in the planter would make it have a max spacing of a lil over 2 feet but ill have to get my book i think thats where i read it
yeah found the info on spacing gotta have a 12 cell plate and the 9 tooth sprocket that doesnt come with the planter it says something about a drilling distance attachment to double the spacing so if i had that the 9 tooth sprocket and a 12 cell plate that would put my plants at about 4 and a half feet apart almost perfect for pumpkins wonder where i could dig up a distance attachment at lol
   / jd 71 planter pumpkin seed plate #7
My nieghbors plant with a model 290 JD planter that uses the same plates as a 71. They simply take any old plates and block most of the openings with epoxy (JB-weld, etc). You can also enlarge the openings with a grinder if necesary. It is very easy to get a perfect match for any seed size or plant spacing requirement using this method and starting out with any plates.
ok after much searching and wondering i found the answer right in the paper that came with the planter its amazing what you can find when you read something lol ok here goes the pumkin plate is a 12 cell plate and the plate number is B27436 also you have to use the false ring Y2630B OR THE H1346B FLOOR PLATE by the way this is for large pumpkin seed for anybody else thats been lookin for this info we finally got it!!!!!!!!!!!!!!! woo hooo
ok anybody know where i can the 9 tooth sprocket for the 71 planter if i can get that ill be set for planting THANKS MR. BOOTH THOSE PAGES WILL COME IN HANDY THANKS FOR YOUR HELP
   / jd 71 planter pumpkin seed plate #10
I think you may have a hard time finding the B27436. I have only ever seen one on ebay. I use my cole 12mx planter for pumpkins and squash but have set up one of my 71's for pumpkins as well. I use the Lustran B015-16 sunflower plate with false ring BFR-2. I filled in all but three of the holes and enlarged those to fit 2-4 seeds. I use two 14 tooth sprokets for 40"-44" spacing.
PT 18' x 8' 4-Wheel Wagon (A44501)
PT 18' x 8'...
2015 MACK GU (GRANITE) INOPERABLE (A45046)
2015 MACK GU...
1979 Trail 40 ft Hopper Bottom Grain Trailer - Dual Grain Doors and Leaf Spring Suspension (A44789)
1979 Trail 40 ft...
John Deere Gator HPX615E 4x4 Utility Cart (A44572)
John Deere Gator...
Daewoo SL220LC III - Excavator (A42203)
Daewoo SL220LC III...
New/Unused 72inch Greatbear Rock Bucket (A44391)
New/Unused 72inch...
