jimgerken
Veteran Member
I noticed my "new" 71 planter has a couple minor issues. On one unit, the press roller wheel has a lot of play, so I assume that the bearing is out. Also, on the other unit the assembly is backwards (the hub that tht wheel bolts to is pressed onto the shaft inside out). I took the wheels off. I removed completely the jamb nut and set screw that apparently contacts the bearing or shaft. I took the cover off the chain housing, and removed the bolt that holds on the drive sprocket (threads into the press wheel shaft or hub on end of shaft). I tapped on the sprocket mounting end of the shaft, from inside the chain housing, toward the wheel-direction. Looking at the picture in the manual ( a Yetter 71 manual I got off the internet), there seems to be a hub on the end of the shaft, that provides the sprocket mounting provisions. Maybe this has to come off first somehow? Could it be that a LONGER bolt (7/16" I think) inserted into the hub part will press it off the shaft? Thats my best guess at this point, but I'd sure appreciate hearing from someone who has had this apart before. Thanks!
