JD 655 Tiller Used
   / JD 655 Tiller Used #1
CountryBoy 72
There is a used JD 655 Tiller for sale at a local eqipment dealer, he is not a tractor dealer. Never used a 3 pt tiller either. It will be going on my 2520, know this is one of two that JD says I can use for my size tractor. Priced out a new 655 an the dealership wants 2898.00.He wants 2000.00 for it. Just from looking at it, the unit looks like its in really good condition an barely used.
Just wondering what you look for when it comes to used tiller units ?
Without hooking it to the tractor is there anything, or any signs that give it away that the unit is broken or been abused ?
Is there a badge that will tell me when the unit was produced ?
If there is, where will it be located ?
   / JD 655 Tiller Used #2
Check gearcase oils and chaincase oil. If they are clean levels are good. I would think it would be a good purchase. Also could check to see if you can feel bearing play by lifting up on the tiller shaft.
I have to ask how you check the oils ? Is there a bolt i can remove, or do they have dipsticks ? How much play should there be in the shaft ?
   / JD 655 Tiller Used #4
Shaft will have a definite slop if bearing is out. Chaincase i think has a sight glass. Gearcase will either have a plug on the side. Or a breather plug on top with a tube that you sjould see oil on.
Thanks Jdmano.If the bearing is getting sloppy, or worn. Are they expensive to replace ?
   / JD 655 Tiller Used #6
One pf the bearings is about 55 bucks. Proper maintenance goes a long ways. Just keep reminding yourself how much grease and oil you can use for 55 bucks.
I definitely like to take care of the attachments and the tractor. Some people on the other hand don't. Will probably change the fluids right away and grease what needs it, If I buy it. Grease is free, I make sure things are greased regularly. Offered him less than what he was asking, will see whether he goes for it or not.
What needs to be greased on a tiller unit ? How often do the oils need replacing ?
   / JD 655 Tiller Used #8
The bearing opposite of the chaincase and the pto driveline. Inspect slip clutch for proper adjustment as well as inspect pto drive shaft length to prevent damage to your tractor and tiller. Gearcase and chaincase oil i would say 100 hours or yearly. Depending on amount of use. One thing i forgot to mention is inspecting tines to make sure none are cracked or broken. And bolts and hardware is tight. Of course always refer to operators manual for best operation and maintenance.
   / JD 655 Tiller Used #9
Another tip is not to back up with tiller in the lowered position and running. The loose dirt you just tilled could cause the rear shield to be pushed under and get grabbed by the tines. Seen it happen. Not good.
What about shaft length; how will I know if its too short or too long or just the right length ?
KENWORTH T800 (A50854)
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A51039)
Kubota SVL65-2...
2015 CHEVROLET SILVERADO CREW CAB TRUCK (A51406)
2015 CHEVROLET...
2010 Triple B Gooseneck Inclosed Car Trailer (A50514)
2010 Triple B...
2017 JLG Skytrak 6036 6,000LB 4x4 Rough Terrain Telehandler (A50322)
2017 JLG Skytrak...
2012 International Semi Truck (A50323)
2012 International...
