Aug 15, 2013 / JD 655 Starting When Hot #1 J JD 655 New member Joined Aug 15, 2013 Messages 2 Location Lumberville, PA Tractor John Deere 655 After mowing 2-3 hrs with my JD 655 when it's hot, but not overheated, it won't start unless it's cooled off for 3-4 hrs and then it starts right up. Any idea why it won't start when hot?
Aug 15, 2013 / JD 655 Starting When Hot #2 G Grahamguy Member Joined Jun 24, 2013 Messages 26 Location Graham, WA Tractor Kubota BX25 FEL, BH, Land pride Post hole digger, JD X300 mower. Land pride GS1548 Grading Scraper What do you mean that it " wont start"? Will it turn over but wont fire or you turn the key and nothing happens?
Aug 15, 2013 / JD 655 Starting When Hot Thread Starter #3 OP J JD 655 New member Joined Aug 15, 2013 Messages 2 Location Lumberville, PA Tractor John Deere 655 Hi, Grahamguy Won't turn over when key is turned to start position. Oil, battery, and temperature lights come on but starter does not activate
Aug 16, 2013 / JD 655 Starting When Hot #4 Tx Jim New Member Joined Jan 26, 2007 Messages 10,298 Location Coyote Flats,Tx Tractor JD 4255/Kubota M7040 HDC Starter solenoid probably binds from heat not allowing magnetic plunger to operate.
