JD 650 start issue/wiring diagram
   / JD 650 start issue/wiring diagram #1
dungbeetle07
TN
A friend has a 650 with start issues, starter will not turn over, battery has good voltage. He doesn't have any manuals so I don't have a wiring schematic. Does anyone have a start circuit diagram they could send? Or if you guys have any sugg's. I know there's a seat switch but I'm not smart on any other types of swithes in the circuit. Thanks!
   / JD 650 start issue/wiring diagram #2
Try the PTO safety switch under the seat on the left side as you sit on the tractor or the neutral safety switch to the left of the gear shift (its under the cover). Take them to the JD dealer and have them tested. He might want to take the seat off and have that tested also. If all else fails try the starter. You can find the wiring diagram at www.jdparts.com. I had the same problem with mine tore it all apart, cleaned all of the wires and connections, had the sensors, Battery, & started tested - all was fine put it back together and it started right up. I hope this helps
JD Green
2012 Ford E-150 Passenger Van (A51692)
2012 Ford E-150...
2025 New/Unused Wolverine Hydraulic Skid Steer Pallet Forks (A51573)
2025 New/Unused...
New/Unused 48in Quick Attach Pallet Forks (A51573)
New/Unused 48in...
2025 New/Unused Wolverine Concrete Breaker (A51573)
2025 New/Unused...
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A52377)
2014 MultiQuip...
JOHN DEERE 50G EXCAVATOR (A51246)
JOHN DEERE 50G...
