Grading jd 650 blade on a YM165
   / jd 650 blade on a YM165 #1
gws
Platinum Member
yanmar ym1810
Has any tried to install a JD 650 snow blade on a Yanmar ym165?
The blade is similar to this one snow blade.
Anyone else come up with a snow blade option for the 165?
   / jd 650 blade on a YM165 #2
The blade looks like it is in good shape.
Although I can't specifically answer your question, I have a pretty similar setup. On my YM169d I have a JD 375 blade. The 375 blade seems to be a bit shorter and have a different under-carriage beam/setup. My concern for your 165 and the 650 blade is that the under-carriage beam might be too long for the tractor wheel base. Can you take measurements and have the seller confirm lengths, etc.?
Also, does your 165 have 4x4? If not, I wouldn't try pushing a whole lot with the blade-- for instance, even in 4x4, the 169d can only move about 10" of snow before beginning to struggle...
good luck! -Art
2014 MACK CXU613 (A50854)
2014 MACK CXU613...
2006 CHEVROLET EXPRESS SERVICE VAN (A51219)
2006 CHEVROLET...
2021 POLARIS XP1000 RANGER (A51222)
2021 POLARIS...
2008 FREIGHTLINER M2 FLATBED (A50854)
2008 FREIGHTLINER...
Set of Ag R4 Wheels and Tires (A51039)
Set of Ag R4...
2015 MACK GU 713 (A50854)
2015 MACK GU 713...
