If the alternator is not charging, chances are good that the regulator is bad. disconnect the wires at the alternator and check for AC voltage coming out of alternator while running. Should see around 30 AC volts at wide open throttle. If that is correct, then replace the regulator. Those dynamo style alternators rarely go bad other than bearing failures.
