Jd 6420 transmission overheating
   / Jd 6420 transmission overheating #1
Pwquist
Jd 6420
Transmission overheats after operating a 926 disc mower or 348 baler for 2 to 3 hours. I've checked the obvious. Changed. Oil filters cleaned screen. Cleaned radiator. I've noticed the on my two scv controls that the have been set on rabbit. Temp with heat gun on transmission case gets to 230 degrees. Could the setting on the scv controls effect the transmission overheating? Thanks
   / Jd 6420 transmission overheating #2
On a closed center hydraulic system, the pump will run all the time if there is an internal leak causing it to overheat.
JOHN DEERE RC7 R LOT NUMBER 224 (A53084)
JOHN DEERE RC7 R...
2023 UNVERFERTH 632 LOT NUMBER 179 (A53084)
2023 UNVERFERTH...
MAHINDRA 6110 TRACTOR (A51247)
MAHINDRA 6110...
2013 Ford Edge Limited AWD SUV (A51694)
2013 Ford Edge...
Bobcat 14" Hydraulic Asphalt Plainer (A52384)
Bobcat 14"...
2007 DELTA TRAILER (A52472)
2007 DELTA TRAILER...
