JD 630 pulley hot
   / JD 630 pulley hot #1
jhansen17
Omaha, NE
John Deere 630
I drove my 630 25 miles to a parade and when I got there, my pulley was hot. This doesn稚 seem right to me. There is also some oil around the inside edge. What壇 I break and how do I fix it?
Thanks,
Josh
   / JD 630 pulley hot #2
Hand clutch fully engaged and snapped in?
May be a bearing, and would suggest going in and adjusting the clutch..
Should not get hot.
Tractor new to you?
Some pics would be great.. of the tractor and of the area where you are seeing oil.
   / JD 630 pulley hot #3
Only time clutch brg on a 2 cylinder rotates(spins) is when clutch is disengaged. Hot clutch when engaged would be due to linings slipping IE clutch adjusting nuts not tight enough.
2004 Ford F-550 Wrecker Truck (A51692)
2004 Ford F-550...
2014 Ag Spray Schaben Sidedresser (A53473)
2014 Ag Spray...
ECHO SRM-2120 GAS WEED EATER (A51248)
ECHO SRM-2120 GAS...
(10) 24' CORRAL PANELS (A51247)
(10) 24' CORRAL...
2012 VOLVO ECR305CL EXCAVATOR (A51246)
2012 VOLVO...
2021 CASE IH 345 LOT IDENTIFIER 135 (A53084)
2021 CASE IH 345...
