JD 6200 SCV Leak
   / JD 6200 SCV Leak #1
Industrial Toys
Super Star Member
Ontario Canada
Kubota R510 Wheel Loader + Cab and backhoe, JD 6200 Open Station, Cushman 6150, 4x4, ten foot 56 hp Kubota diesel hydraulic wing mower, Steiner 430 Diesel Max, Kawasaki Diesel Mule, JD 4x2 Electric Gator
I have been finding a big puddle of oil under the rear end of the tractor lately. It seems that the Stupid tiny bottle that is supposed to catch the droplets of oil that are lost when you plug or unplug a coupler is FULL and over flowing!
So where is this AMOUNT of oil coming from, to create a big puddle in such short time?
I have my rear snow blower on with the hydraulic chute control so I am using one SCV.
I started looking at the SCVs closely. There is a pipe barb in four places on each coupler. Front and back, upward and downward. The upward ones are just to accomodate the top SCV, I believe. Some have hoses going to that tiny bottle, some have nothing.
So my question is:
What is the purpose of the drain barb, front AND back on the SCVs?
The tractor has over a thousand hours and is a 96 model. Are there parts or seals in the SCV that get old, worn and fail? Actually when I think about, I bought that SCV spool used so I really don't know how old it is. But I would think that most of the oil would be lost when I operate the SCV not sitting in the barn.
At first I thought maybe my loader circuit was leaking and if it wasn't lowered completely to relieve pressure this would account for the puddle while parked, but I don't think this is the case after seeing the bottle overflowing.
Thanks for any help.
   / JD 6200 SCV Leak #2
You have the deluxe couplers if you have the drains.
You are right top barbs are to connect to coupler directly above. Upper barbs on top coupler should be capped.
Reason for front and back is the ones closest to rear of tractor, could have dirty oil from the open ends of the couplers, so these go to the catch bottle for disposal.
The ones closest to the SCV catch oil that is considered clean oil and hoses from them connect to the oil fill tube for your transmission.
Your quick couplers need to be rebuilt, not your SCVs.
   / JD 6200 SCV Leak
Thanks. That makes sense. Is that an expensive repair or just some new O rings?
   / JD 6200 SCV Leak #4
Just O-rings. You need to look on JDparts.com there are two different deluxe couplers. Then check for seal kits.
   / JD 6200 SCV Leak
Thanks! Unrelated, but how is your 6415 on fuel?
2007 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2007 DRAGON 150...
2004 Kenworth T800 Day Cab T/A Truck Tractor (A52377)
2004 Kenworth T800...
ROLL OFF BOX (A53843)
2002 Wacker RD11A Tandem Smooth Drum Roller (A54811)
2002 Wacker RD11A...
Heavy-Duty D-Ring Shackle Set (A53117)
Heavy-Duty D-Ring...
2022 McConnel TRAXX RC28 43in. Remote Controlled Slope Mower (A54815)
2022 McConnel...
