JD 6110 reverser quits working when engine warms up
   / JD 6110 reverser quits working when engine warms up #1
cowsrus
Bronze Member
NE Oklahoma
JD 6110, JD 5510
16 sp/ right hand reverser. When operating tractor for long periods like mowing hay or baling, as long as you don't stop, you're ok. You can stop with clutch and then go, but if you stop and put in neutral, it won't go forward or reverse until tractor cools down a little, then it's good to go unless you stop and put it neutral again. It's been doing this for a couple of years but it's getting worse. Tried to mow some hay today and after about an hour it did it. The tractor is running in the green, but almost in the red. The tractor does get hot and I have to turn the a/c off sometimes, but that's another problem. The other day I was baling some really heavy windrows and had to back up a lot and it was giving me fits. I don't think it's a wiring problem, because the only time it will f up is when the tractor has been running for an extended period. Any ideas?
   / JD 6110 reverser quits working when engine warms up #2
Does it set any trouble codes?
Do you have MFWD? If so, is it in use when the problem occurs? The reason I ask is maybe there is an internal leak for that system's hydraulics causing the hydraulic oil to heat up. PTO system hydraulics might be the cause too if there is an internal leak that heats up the oil.
Have you checked the clutch system pressures? The is a test port marked "Clutch" With the pedal "UP" you should have 170psi. With it down 0psi.
   / JD 6110 reverser quits working when engine warms up #3
When you say right hand reverser, that means you have lever in right console with Park, forward and reverse? If so, there is no electrical control to keep transmission from driving. There must be a shift valve sticking when hot. May need to remove valve body from bottom of transmission and check valves.
Yes it is on the console, i will ck the bottom of the trans.
i was baling today and it was doing it again. I'm thinking it may be the hyd fluid getting hot and causing the prob. The tractor overheats when i'm running the a/c and that may be part of the problem.
I don't have mfwd and my dash is inop, only thing that works is the rpm and the trouble lights.
   / JD 6110 reverser quits working when engine warms up #6
Good morning, I know this is an old post but my neighbor has a 6110 that's having the same problem. Did you figure out what was causing your problem? If so, what was it? Thanks
   / JD 6110 reverser quits working when engine warms up #7
WeB
:welcome: to TBN
Suggest you click the cowsrus forum name, and send a PM with your request for more info.
Appears that there have been few if any more posts since that one 4 years ago from this member.
He/she may like to know that there is further interest from you, and can add to this thread.
Good luck.
Others may chime in and have something to offer as well. Sorry that I don't.
   / JD 6110 reverser quits working when engine warms up #8
Thanks for the advice! I'll give it a try. I have just signed up but I have used this forum to get valuable info for years.
2019-2024 Dodge Ram Front Bumper (A49461)
2019-2024 Dodge...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A51039)
2018 John Deere...
2014 MACK ELITE LEU613 GARBAGE TRUCK (A51243)
2014 MACK ELITE...
2022 Down2Earth 82in x 36ft Two-Car Hauler (A51039)
2022 Down2Earth...
2012 FREIGHTLINER CASCADIA (A50854)
2012 FREIGHTLINER...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50324)
2018 Toro Grounds...
