JD 606 Rotary cutter specs & thoughts
/ JD 606 Rotary cutter specs & thoughts #1
nvmyhd
Peyton, CO
LS XR4155HC
I'm about to buy a John Deere 606 mower and I wondered in anyone had the tech specs on it. (deck thickness, weight, gear box HP)
I'm unable to find a PDF that I don't have to pay $60 for but did find paper for $25 or more on Ebay & amazon.
Technical Manual TM1394
Operator's Manual OMW35179
I borrowed the mower last year to cut my 37 acres and was happy with it. I even repainted it and sharpened the blades before returning it. The current owner owner has upgraded his JD tractor and bought a bunch of new equipment with the deal.
Problem is I just bought a Priefert RMS 600 and plan on selling it to fund the JD. I'm positive that it is a upgrade but just wanted to compare #'s.
The JD could use new blade but they are just fine I don't do any heave cutting, just field grass. It has a stump jumper, chain shields and clutch.
425321d1431916945t-proud-owner-new-owners-manual-forumrunner_20150517_204228-png
The Priefert is darn near new, the paint is great, blades new, 12g deck, rubber front & rear shields... it uses shear bolts and I would not describe it as a stump jumper.
I figure I can sell the Priefert for $800+ I bought it for $650 and have not used it.
I'd be buying the 606 for $1000
Let me know your thoughts
/ JD 606 Rotary cutter specs & thoughts #2
I dont know which one is the best but if you were close Id be interested in the blue one.
Landhonor 31" Mini Excavator Bucket (A66285)
Landhonor 31" Mini...
EZ Trail 3400 Gravity Wagon (A66285)
EZ Trail 3400...
2016 Freightliner 108SD (A64194)
2016 Freightliner...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
Linx EQ07020RS 20ft Trailer (A65640)
Linx EQ07020RS...
New/Unused Landhonor 26ft x 13ft Metal Carport (A65583)
New/Unused...
