JD 606 or Woods 72
/ JD 606 or Woods 72 #1
swmich42
Bronze Member
Southwest Michigan
2000 John Deere 4700 4x4 Hydro
Looking for brush hog. I have approx 5-7 acres, and about 1.5 miles of trails to keep open. I have admired the JD 606 for it's strength, however am having no luck in finding reasonable used price. Woods is another great brand, that are also hard to find used, in good condition. Any suggestions?
/ JD 606 or Woods 72 #2
You may want to try the John Deere MX series as they are billed as the medium duty rotary mowers. As the MX series is the medium duty variety, there are a few more of them around (both new and used) as the price isn't as steep as the heavier series you mention. For the number of acres you mention, I feel the MX series is more than enough to get the job done. I was looking a few years ago and decided on an MX5. I pull it with a 50 hp JD2020 tractor and it works great. I mow about 20 acres with it, so it isn't the fastest way to mow, but it has cut through everything I have asked it to go through. I paid $1700 for the MX5 new, so you should be able to get a good used one for a lot less than that.
Thanks for the advice. I have been eyeing a 616, and an MX6. Feel the MX6 might have won out for choices. I found but lost out on a 606 for a great price. My only concern on the MX6 was the 2" max cutting capacity, vs the 606 4" cutting capacity. But like you pointed out, with such small area to cut, the Medium duty cutters will do the job fine. Thanks again.
