JD 5525 Adding Air Ride Seat
   / JD 5525 Adding Air Ride Seat #1
ddivinia
Elite Member
Red Oak, Texas
JD 5525 and 5093e Kubota SVL75
I want to add an air ride seat to my 5525. My dealer is saying it can't be done.
What is the deal?
Anybody add one?
Thanks,
D.
   / JD 5525 Adding Air Ride Seat #2
Ask why it won't fit.
I have a 5520 and wonder if the slope of the platform is an issue. Seems to me the 5525 had that seat as an option on the cab model.
   / JD 5525 Adding Air Ride Seat #3
A welder and some scrap steel take care of that problem.;)
You got on board compressed air ?
   / JD 5525 Adding Air Ride Seat #5
The air ride seats have a built-in compressor.
Really ?, kool,,,,could it serve double duty with a small tank and hose/nozzle to blow off pants legs before climbing in ?
   / JD 5525 Adding Air Ride Seat #6
What is the deal?
Anybody add one?
Thanks,
D.
What model 5525 do you have? If it is a cab or IOOS(isolated open operators station), it should bolt right in. If is a straddle mount, fabrication would be needed, not to mention the cushions on air ride seat are cloth, so they would need protecting from the elements on open tractors. .
   / JD 5525 Adding Air Ride Seat #7
What is the deal?
Anybody add one?
Thanks,
D.
What reason did the dealer give?
None given.
I am going to ask again, but a different person.
I am going to be up there when they are working on my "new" JD 346 baler. So I will ask the guys in the back what the real story is on it.
D.
   / JD 5525 Adding Air Ride Seat #9
Here's a different thought..go to the Deere parts homepage and look at a parts book with expanded views. That will tell you what fits and where. As well, it will show pictures so you can maybe figure it out. If no dice, you could call an aftermarket seat maker to see if one is available or not and why or why not. They would likely know more than the dealer and probably built the seat for JD.
I have learned most of the "nope, can't do it" answers in life have more to do with people who give up too easy or from those looking to influence others for whatever reason. Just my two cents.
Maybe I should buy a 5105M and hand the 5525 to my wife. :)
D.
2013 JLG 8042 TELEHANDLER (A50854)
2013 JLG 8042...
2005 OTTAWA T2 YARD SPOTTER (A51222)
2005 OTTAWA T2...
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A49461)
2009 Trail King...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A51039)
Kubota SVL65-2...
2013 VERMEER RTX1250 RIDE ON TRACTOR (A51242)
2013 VERMEER...
5K ANNULAR BLOWOUT PREVENTER (A50854)
5K ANNULAR BLOWOUT...
