JD 550 tiller
   / JD 550 tiller #1
twodogs
Pittsburgh, PA
Kubota B7800
I just picked up a 550 tiller this weekend. If anyone has a user manual & can tell me some specs (fluid caps, etc.), I would greatly appreciate it.
   / JD 550 tiller #2
twodogs, I have a manual that covers the 550 and 660 tillers. Any certain spec you are looking for? Maybe I can scan the pages you need and email them to you.
Specifications:
cutting width- 50 inches
tilling depth 1-8 inches
final drive chain No. 100 1-1/4 inches
gearcase capacity 1.1 pint
chaincase capacity 1.3 pints
weight (less slip clutch) 432 lbs.
chain defection should be 10mm or 3/8ths inch.
Both the gear case and chain case call for Deere GL-5 Gear Oil
Sincerely, Dirt
   / JD 550 tiller
thanks for the info. i was concerned about capacities & oil type. i have a leak at the side, of the tiller. i am going to tear it down & replace the seal.
   / JD 550 tiller #4
They are great tillers..........4 passes and you can have grass looking like potting soil.
Sincerely, Dirt
2005 PETERBILT 379 DAYCAB (A45333)
2005 PETERBILT 379...
Transmission-Allison 9820 (A45333)
Transmission-Alliso...
AGT Mini Excavator Attachment Set (A44502)
AGT Mini Excavator...
2016 Ford F 250 Ext. Cab Knapheide Service Truck (A42742)
2016 Ford F 250...
2020 Ford F-150 XL (A44501)
2020 Ford F-150 XL...
2001 Ford Ranger Ext. Cab Pickup Truck (A44572)
2001 Ford Ranger...
