JD 54D MMM drops while mowing
   / JD 54D MMM drops while mowing #1
TN Rambler
Manchester, Tennessee
2012 John Deere 2320
I have a JD 2320 with a 54D MMM with independent lift and diverter valve option. The MMM is raised and lowered using the FEL joystick. When the deck is raised it will gradually drop back to the lower stop. Has anyone else had this problem? If so how do I correct it?
   / JD 54D MMM drops while mowing #2
Either the cyl or the valve needs some work.
Most likely cyl seals.
Test the cyl for pressure holding and leakage.
If the FEL has load checks, inspect them for debris or damage.
STORAGE FEES (A54607)
2020 FREIGHTLINER DEBRIS BUCKET TRUCK (A51406)
2020 FREIGHTLINER...
John Deere 3PT PTO Post Hole Digger (A55218)
John Deere 3PT PTO...
2021 CATERPILLAR 242D3 SKID STEER (A51406)
2021 CATERPILLAR...
2016 PETERBILT 579 TANDEM AXLE MID ROOF SLEEPER TRUCK (A54607)
2016 PETERBILT 579...
UNUSED CFG INDUSTRIAL MX15RX EXCAVATOR (A52706)
UNUSED CFG...
