JD 5420 vs JD 5425
   / JD 5420 vs JD 5425 #1
Zebra5
Bronze Member
Since I intend to buy used, the main difference I see is the 5425 has the same engine but Turbo charged with the same HP. Is this an advantage? or a mute point? Any difference in torque? I am thinking a turbo is one more thing to go wrong, but maybe more fuel efficent?
The 5425 has an electric control for the Reverser, vs a mechanical on the 5420, any pros or cons for either?
The advantage I see to buying a 5420:
Is lower price.
The advatages I see to buying a 5425:
E-PTO availble with the PowerReverser
May have warranty left
Increased Hydraulic Gpm
Since price will not be the only deciding factor i am leaning towards the 5425, unless a 5420 would be more trouble free.
   / JD 5420 vs JD 5425 #2
I absolutely love my 5420.
The turbo should make the unit a little more efficient and certainly quieter. I wanted the 5425 because of the turbo, for the reasons stated, but I have done well without.
The mechanical PowerReverser lever is a bit clunky, but it is very positive. You KNOW what direction you are going in and it NEVER pops out.
I can not speak to the other points except to say that the hydraulic flow on my tractor is sufficient to run a concrete breaker and post hole digger.
I use my tractor about everyday for utility work through making hay. In my opinion, it is an awesome hay making tractor. Just the right size.
2025 Bale Spear Skid Steer Attachment (A49346)
2025 Bale Spear...
Feed Bunk (A49339)
Feed Bunk (A49339)
Brillion Seeder (A49251)
Brillion Seeder...
2004 Chevrolet C5500 Shuttle Bus (A46683)
2004 Chevrolet...
2012 Hyundai Sonata Hybrid Sedan (A46684)
2012 Hyundai...
Golf Cart (A48082)
Golf Cart (A48082)
