Oil & Fuel JD 540 Kawasaki Engine (Carb) manual available?
   / JD 540 Kawasaki Engine (Carb) manual available? #1
jimgerken
Veteran Member
Minnesota
John Deere 3720
I have a 2006 or 2007 JD 540 lawn tractor. It has run a bit lean at and near idle since it was new. I took it back to dealer and had it serviced, came back a little better, but has since gradually slipped into annoyingly lean again. So the symptom is, it idles, but it revs a bit and settles, again and again. I guess it does this cause there is a governer involved. Whatever, what I'd like now is a picture of the carb, showing the low speed jet location. I'd like to increase fuel flow at low RPMs to make it smooth out. I am capable and willing to remove the welch plug if needed. Does anyone know where on-line I can look up to see a pic of the carb showing the parts labeled? Or, can I buy an engine manual which includes the carb diagram? I guess I could go back to the dealer and ask if he has such a diagram, and maybe just get a copy of that page. Any ideas? Thanks!!!
The Kawi says: 685N4G2 KAXS 675N4CB
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2018 JLG 3246ES 32FT. Scissor Lift (A51691)
2018 JLG 3246ES...
KJ 23'x22' Double Garage Metal Shed (A50121)
KJ 23'x22' Double...
2015 Ford F-250 Knapheide Service Truck (A51692)
2015 Ford F-250...
New Holland L225 Skidloader (RIDE AND DRIVE) (A50774)
New Holland L225...
