JD 5310 no low beam headlights.
   / JD 5310 no low beam headlights. #1
cmattson
JD 5310
I have a 5310 that the low beams will not come on but high beams will. Warning lights are working. Replaced light switch and flasher, cleaned the ground by the battery. All fuses are good. Power leaving the switch. Bulbs have continuity and work on high so believe they are fine. What am I missing?
   / JD 5310 no low beam headlights. #2
I know it doesn't seem likely, but isn't there a chance that the low beam filaments are bad in both bulbs? I think I'd eliminate that before I started trying to go farther.
Can you put a voltmeter on the modular plug terminals to verify that there is NO voltage on the LOW BEAM setting? You should see voltage when on the HIGH terminals but not when on the LOW terminals. If there is voltage, I'd replace the bulb.
If this doesn't lead to a resolution, I'd drink a beer and decide whether I really needed the LOW BEAM setting.
2021 CATERPILLAR 953 CRAWLER LOADER (A51242)
2021 CATERPILLAR...
2021 Case IH Magnum 240AFS CVX Connect MFWD Tractor (A50657)
2021 Case IH...
2015 FREIGHTLINER M2 (A50854)
2015 FREIGHTLINER...
2021 McFarlane IC-5140 Vertical Tillage Tool (A50657)
2021 McFarlane...
2022 FREIGHTLINER CASCADIA SLEEPER (A51222)
2022 FREIGHTLINER...
2012 FREIGHTLINER CASCADIA (INOPERABLE) (A50854)
2012 FREIGHTLINER...
