JD 5310 Brake Retractors - Replace or Discard?
   / JD 5310 Brake Retractors - Replace or Discard? #1
Doug Bradenton
Wrightsville GA
John Deere 5310
I have a JD 5310. I have the brakes dragging and the fluid boiling and losing brakes after running a few minutes. I have read several posts regarding the defective factory brake retractors and the brakes dragging in the 5000 series tractors being a common thing. I have also read where one guy paid JD Dealer to fix his and he had the same problem again. I am a skilled mechanic and prepared to fix this item. I have one question. What is the consensus on what to do with the brake retractors upon repair? Do I perform the repair and leave out the brake retractors or has JD developed an improved brake retractor pin that eliminates this problem? Thanks for any suggestions.
   / JD 5310 Brake Retractors - Replace or Discard? #2
Thanks JD 5210. I have a detailed repair manual. I have reviewed that you tube video. I replied to his video a month ago asking what he found but he did not reply and as you said he did not post a follow up video. But he did indicate he had a dealer replace the retractors and the brakes dragged again after use.
   / JD 5310 Brake Retractors - Replace or Discard? #4
I did mine about 2 yrs ago and I think theyre starting to drag again.....I don't have an answer tho
I am getting ready to perform the repair over the next two weeks. I was just wondering if anyone had any more information on the brake retractors and whether to reuse or delete them from the repair. Thanks.
Wondered if you had any late info. I am getting ready to work on my tractor.
   / JD 5310 Brake Retractors - Replace or Discard? #7
I discarded the retractors and replaced the brake disc. No problem now
   / JD 5310 Brake Retractors - Replace or Discard? #8
My thoughts are JD utility tractors had no brake disk retractors springs from '64-'92 then brake retractor springs were added I think in hopes of lowering GPH fuel usage. I've read several instances where brake disk retraction springs have be removed with good results
UNUSED JCT HYD HD BACKHOE ARM (A51248)
UNUSED JCT HYD HD...
WESSEX AT110 LOT IDENTIFIER 157 (A53084)
WESSEX AT110 LOT...
2023 John Deere 8R 410 Tractor (A53342)
2023 John Deere 8R...
2012 KINZE FLAT FOLD ROW MARKERS SET FOR 12 ROW 36/38 STACK FOLD TOOL BAR (A53472)
2012 KINZE FLAT...
(2) UNUSED 7000# DROP AXLES W/ BRAKES (A51247)
(2) UNUSED 7000#...
2021 CATERPILLAR D4 LGP CRAWLER DOZER (A51246)
2021 CATERPILLAR...
