JD 5310 Brake Retractor Springs
   / JD 5310 Brake Retractor Springs #1
Doug Bradenton
Wrightsville GA
John Deere 5310
I have seen this subject posted numerous times but there is never a definitive response. I am getting ready to repair the hydraulic wet brakes on my JD 5310. The brakes are locked up. There was water in the fluid which I know has ruined the brake pads. However, there is a ton of talk about the brake retractor springs being poorly designed and failing. I have experienced problems with the brakes locking long before water got in the tractor due to a torn shifter boot. Some people talk about leaving the retractors out after the repair and discarding them. Most agree the original retractors were defective due to springs which become prematurely weak and defective causing the brakes to lock.
Does anyone know if they have come out with new and improved retractors? Has anyone done the repair and just left the retractors out of the repair? If so, how did they brakes function without the retractors? I am in the middle of the repair and I have to decide whether to replace the retractors or eliminate them from the repair. Since the retractors are deep within the axle housing, I don't want to have to go back in and do the repair again. Thanks.
2002 Ford F-650 Crew Cab Dump Truck (A48081)
2002 Ford F-650...
2022 John Deere 8R 310 MFWD Tractor (A53342)
2022 John Deere 8R...
UNUSED HURRICANE 20' X 20' ALL-STEEL CARPORT (A51248)
UNUSED HURRICANE...
SCAN TO RECEIVE TEXT UPDATES (A51248)
SCAN TO RECEIVE...
UNUSED RAYTREE RMAU2 AUGER (A51248)
UNUSED RAYTREE...
APPROX 500 GALLON FUEL TANK (A51248)
APPROX 500 GALLON...
