Aug 1, 2017 / JD 5303 pto shaft #1 G Goatwhiskers New member Joined Dec 15, 2014 Messages 4 Location Batchelor, La. Tractor Kubota L2350 Need info on how to adjust clutch. Shaft continues to turn when engine is running, clutch disengaged. Thanks, GW
Aug 1, 2017 / JD 5303 pto shaft #2 B beenthere Super Star Member Joined Aug 16, 2001 Messages 18,546 Location Southern Wisconsin, USA Tractor JD_4x2_Gator, JD_4300, JD_425, JD_455 AWS, added JD_455, JD_110, JD_X485(sold) Do you have the manual? Is there something like this on the pto clutch? OMRE268160: 5103, 5203, 5303 and 5403 Tractors, Block File: SA61034_0000064_19_22NOV07.htm
Aug 2, 2017 / JD 5303 pto shaft Thread Starter #3 OP G Goatwhiskers New member Joined Dec 15, 2014 Messages 4 Location Batchelor, La. Tractor Kubota L2350 That's the very thing. Good to read the words, keeps the details in order. I had found that when the lever is pulled firmly back to disengage, then the pto shaft is free, so a minor adjustment should take care of things. GW
