JD 5300 brake replacement ???
   / JD 5300 brake replacement ??? #1
ervinedonniebob
Arbovale, WV
96 Agco 6670, 96 Deere 5300, 2 Int 444, 90 Ford 2120, Dresser TD7G Dozer, Dresser 125E Loader, M-B Motor Grader
HI everyone,
I am in the process of putting new brakes on my 96 5300, when I got the first side apart the pressure plate was seized. I was told that the little return springs cold be part of the problem and not to put them back in. Has anyone else had any experience with 5300 brakes seizing up and did you put the springs back in when you put them back together?
Donnie
   / JD 5300 brake replacement ??? #2
Recently been a thread or two on the springs in these brakes, IIRC. Maybe a search (albeit that is tough to do a search on TBN) will bring something up for you, or someone will chime in shortly to help out. Hang tight.
   / JD 5300 brake replacement ??? #3
The return springs have been the source of problem of brake drag in some cases. I have never tried leaving them out. The springs act as dowel pins to align the pressure plate and I am not sure if things would work well without them. Deere has redesigned the springs a couple of times, so I wouls recommend replacing them with the newer design. If someone would design a dowel pin that would replace the return springs, I thing that would work OK. Any of our machinist members willing to give that a try? Make the dowel be a slip fit into the axle housing. That would make them similar to older tractors before return springs were installed.
1994 Peterbilt 379 Semi (A50514)
1994 Peterbilt 379...
2017 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A50323)
2017 Chevrolet...
2015 VANTAGE TRAILER CRUDE TRAILER (A50854)
2015 VANTAGE...
2008 RIB 24 Cat Boat (A50324)
2008 RIB 24 Cat...
2011 FORD F-450 (A50854)
2011 FORD F-450...
2013 KOMATSU PC490LC-10 EXCAVATOR (A51242)
2013 KOMATSU...
