JD 5205 questions
   / JD 5205 questions #1
ScottAR
Veteran Member
Greene Co, Arkansas
JD 1050 2wd, Case 580D 2wd
I was curious; What is the speed of the lowest gear? I think the tractor is near perfect size and power wise but it needs to go slow enough for a harley or possibe tiller. I've seen a post with the proper info but I can't find it now. TIA...
   / JD 5205 questions #2
IMO a VERY enticing tractor if you're already looking at the high (power/size) end of CUTS - especially if you appreciate mechanical simplicity and straightforward tractors. Unfortunately the tranny does somewhat limit this tractors flexibility. First gear, low range is just 1.86 mph (assuming 14.9-28 R1's). That may be too fast for successful tiller use in some conditions. A creeper option on the '05's would be great but Deere doesn't offer it on the 5000-Fives or an 4000's now. You have to go up to the 5000-Twenty Five series to get a creeper.
Here's a link to the 5000-Five owner's manual - the ground speeds in each gear are listed:
5105/5205 Manual
   / JD 5205 questions #3
On the 4x20 series with the 12x12 tranny, in the A range and in 1st gear, it couldn't really go any slower for me. If it did, it would essentially be stopped. I have only found a few things to do in the 4 gears in A range. Usually (even tilling), I find a useful gear in the normal B range.
   / JD 5205 questions
Thanks for the link! Interesting findings... My 1050 will go 0.8 in low first but it still pulls a tiller ok in low 2nd. If I remember, that's about 1.5 or somthing so the 5205 is a bit fast.
Disappointing, That size machine seems to be about the perfect size. Guess I could use the 52 for heavy ground work and keep the 1050 for finishing up.
Be a real shame to keep two tractors around, dunno how I could manage. /forums/images/graemlins/smirk.gif
   / JD 5205 questions #5
I am attracted to the 5205 also, mainly for plowing with a 3 bottom and being able to go to turfs or r-4s on my 970.
My 970 rototills best in 2nd also for just cutting the top off of turf or shallow tilling 3rd works good.
keep us posted if you get to demo one.
2013 Ford F-450 Altec AT200A 30FT Bucket Truck (A50323)
2013 Ford F-450...
2019 Cat D5K2 LGP Dozer (RIDE AND DRIVE) (A50774)
2019 Cat D5K2 LGP...
2016 Chevrolet Sonic LS Hatchback (A50324)
2016 Chevrolet...
2000 International 4700 Truck (RUNS) (TITLE) (A50774)
2000 International...
2004 Stage Line SL-250 Mobile Folding Stage Trailer (A50324)
2004 Stage Line...
1996 International Bucket Truck (A50323)
1996 International...
