JD 5205 oil fill
   / JD 5205 oil fill #1
HillbillyFarmer
Jackson Co., WV
Coming up on 100 hr service and I can't find where to add oil to the crank case. Had my local extension agent out the other day and he was a baffled as I am!
Manula says to add it, but doesn't say where.
   / JD 5205 oil fill #2
My TN70A fills via the dipstick hole.
Bob
   / JD 5205 oil fill #3
Hmmm, JD Parts Catalog online shows engine oil filler assembly, but doesn't show where it is on the engine. I'm assuming on the right side of the engine, that's where it is on my old 1530 Deere.
   / JD 5205 oil fill #4
hillbilly,if it is similar to my jd 5203,and i believe that it is since they share the same engine,the oil fill is forward of the dipstick.you need to take the rt. side pop off green screen off,for lack of a better word.treat it like you are going to check the battery,its that pop off screen,take it off and look down it should be right there ahead of the dipstick.
hope that i haven't confused you more than helped you,
whitearrow->>>-------------->
   / JD 5205 oil fill
Mystery solved! Thanks whitearrow. Who'd a guessed you needed to disassemble the beast to add oil!
And thanks to the moderators for putting my question where it belonged!
2003 Polaris Sportsman 700 Twin (A51573)
2003 Polaris...
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A52576)
2018 INTERNATIONAL...
66in Light Material Bucket Skid Steer Connection (A53472)
66in Light...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2017 FREIGHTLINER...
2001 CATERPILLAR 140H VHP MOTORGRADER (A51406)
2001 CATERPILLAR...
2015 Ford Econoline Box Van, VIN # 1FDWE3FL4FDA28220 (A51572)
2015 Ford...
