JD 5205 3 pt not lifting
   / JD 5205 3 pt not lifting #1
ggrimm01
Lacygne Kansas
JD 5205 with FEL
Help.....Ok back late this summer my 3 pt starting giving me some problems. I could not get the 3 point to lift after my initial start up. When the tractor starts up, and I have the rock shaft level up in the 1 position....the rock shaft will lift up. After that the 3 point will only go down. I thought I had this problem cleared up. I tore apart the rock shaft control valve and cleaned all the valves and burnished each valve with a burnishing tool. In addition I replaced all the fluids throughout the whole tractor and the filters. I even replaced the internal metal hydraulic filter located down by the diesel tank sending unit.. Today... the problem came back. I cannot get the rock shaft to go up. It seems stuck. Is there anything I can do to correct this problem?
Deere 325G (A50120)
Deere 325G (A50120)
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
Red Iron Oxide in Trace Mineral Supplements for Cattle
Red Iron Oxide in...
2013 Ford F-550 4x4 Ext. Cab Auto Crane 6406H 6,400LB 3 Ton Mechanics Crane Service Truck (A50323)
2013 Ford F-550...
2019 Ford F-150 XL (A50120)
2019 Ford F-150 XL...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
