JD 513 Cutter Seal
   / JD 513 Cutter Seal #1
RobS
Super Member
Goshen, IN
None!
My rotary cutter is leaking gear oil from the lower seal (below the deck). I have an exploded view showing the parts and am prepared to replace the seal myself if I can. Does anyone know if this can be done by simply removing the blade holder and such, or does the whole output shaft need to come out? I'm sure these gearboxes are pretty generic. Thanks ahead of time for the help /w3tcompact/icons/smile.gif
   / JD 513 Cutter Seal #2
<A target="_blank" HREF=http://jdpc.deere.com/pimages/WP39/WP3976_________UN20OCT98.gif>John Deere 413/513 Gearbox breakdown…</A>
KEY PART NO. PART NAME QTY SERIAL NO. 413 513 613 REMARKS
1 19M7395 CAP SCREW 4 X X M16 X 40
2 A31869 LOCK NUT 4 X X M16
3 CE17656 SHIELD 1 X X (SEAL PROTECTOR)
4 CE17707 SEAL 1 X X
5 40M7179 SNAP RING 1 X X
6 DE18710 SOLID SHIM AR X X (A)
7 DC24985 TAPERED ROLLER BEARING 2 -013000 X
JD10038 TAPERED ROLLER BEARING 2 013001- X
DC24985 TAPERED ROLLER BEARING 2 -025000 X
JD10038 TAPERED ROLLER BEARING 2 025001- X
8 BEVEL GEAR DRIVE 1 X X (22T GEAR, 13T PINION SHAFT) (ORDER DE18961)
9 HOUSING 1 X X (ORDER DE18961)
10 CE17706 SEAL 1 -013000 X
DE18644 SEAL 1 013001- X
CE17706 SEAL 1 -025000 X
DE18644 SEAL 1 025001- X
11 15H638 PIPE PLUG 1 X X 1/8", (SUB FOR 15H253)
12 CE17664 CAP 1 -007500 X (ALSO ORDER JD5801)
CE17664 CAP 1 007501- X
CE17664 CAP 1 -016000 X (ALSO ORDER JD5801)
CE17664 CAP 1 016001- X
13 19M7162 CAP SCREW 4 X X M8 X 16
14 15H255 PIPE PLUG 1 X X 3/8"
15 40M7043 SNAP RING 2 X X
16 DE18711 SOLID SHIM AR -013000 X (B)
SOLID SHIM AR 013001- X
DE18711 SOLID SHIM AR -025000 X (B)
DE18711 SOLID SHIM AR 025001- X
17 JD9125 BEARING CUP 2 -013000 X
Z53552 BEARING CUP 2 013001- X
JD9125 BEARING CUP 2 -025000 X
Z53552 BEARING CUP 2 025001- X
18 JD9065 BEARING CONE 2 -013000 X
AZ41923 BEARING CONE 2 013001- X
JD9065 BEARING CONE 2 -025000 X
AZ41923 BEARING CONE 2 025001- X
19 40M7179 SNAP RING 1 X X
20 CE17938 DRIVE SHAFT 1 -013000 X (SUB FOR CE17717)
DRIVE SHAFT 1 013001- X (ORDER DE18961)
CE17938 DRIVE SHAFT 1 -025000 X
DRIVE SHAFT 1 025001- X (ORDER DE18961)
21 CE17685 PLUG 1 -013000 X
CE16346 PLUG 1 013001- X
CE17685 PLUG 1 -025000 X
CE16346 PLUG 1 025001- X
22 JD5801 PRESSURE RELIEF FITTING 1 007501- X
JD5801 PRESSURE RELIEF FITTING 1 016001- X
23 DE18653 GEAR CASE 1 -013000 X (C)
DE18961 GEAR CASE 1 013001- X (C)
DE18653 GEAR CASE 1 -025000 X (C)
DE18961 GEAR CASE 1 025001- X (C)
(A) DE18710 SHIM KIT INCLUDES SHIMS 41 X 55 X 1.5 THRU 2.5 IN .1 INCREMENTS.
(B) DE18711 SHIM KIT INCLUDES SHIMS 60 X 50 X 1.5 THRU 2.5 IN .1 INCREMENTS.
(C) GEAR CASE SPECIFICATIONS:
OUTPUT SHAFT BEARING - .03 MM ENDPLAY TO .07 MM PRELOAD
INPUT SHAFT BEARING - .08 MM ENDPLAY TO .02 MM PRELOAD
GEAR BACKLASH - .15 MM TO .25 MM
COVER BOLT TORQUE - 20 N.M. (15 LB.FT.)
LUBRICANT - JOHN DEERE 85W140 GL5 GEAR LUBE (0.75 L)
   / JD 513 Cutter Seal #3
It appears from the breakdown... after you remove the seal "holder", the output shaft will probably also come out with ease...
You'll want to check the shaft for being true anyways... normally the seal doesn't start leaking unless the shaft has taken a few good hits...
Thanks John, that's exactly the input I was looking for /w3tcompact/icons/smile.gif
SET OF (7) JACK STANDS (A53843)
SET OF (7) JACK...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
2015 Hooper T/A Trailer w/Mounted Foaming System (A53117)
2015 Hooper T/A...
FIRESTONE 9.5L-15 4 RIB TIRES (NEW CONDITION) (A53473)
FIRESTONE 9.5L-15...
Charlotte County (A50323)
Charlotte County...
2013 Ford Taurus AWD Sedan (A51694)
2013 Ford Taurus...
