andrewj
Platinum Member
Hi folks - sure could use some opinions here....
I have a JD 5105 tractor with MFWD made in 2004. Just this year i bought a loader - a 553. Now, when it is in MFWD, and when the loader is empty or full, and when I turn a hard left or right, the front wheels make a sound like a seal..you know, "aaaarf, aaaarf, aaaarf." and when I straighten out teh wheels the sounds stop. or if I take it out of 4wd it stops. I can't tell whether it is cimong from left or right wheel.
there is only one grease fitting on each front wheel and I have greased it. I can see inside the axle housing at the wheel end a 4 way U joint, and it is all sealed so no way to lube it.
I called the JD service dept and they said probably nothing to worry about. My common sense says otherwise.
What do yall think?
What do yall think?
