jd5448
I'm looking at a Woods 720 rotary cutter to clear a couple of acres at my place. I will have to remove many small pine trees 1 to 2 inch in diameter. The 720 is rated to cut brush up to 2 inches, but I'm not sure my tractor (JD 5103) is big enough to handle it (the cutter is a little over 1100lb with 120+ HP gearbox). I have also looked the JD MX6 and Bush Hog 296. All three weigh about the same, cut about the same and are not that much different in price. I quess my real question is: Is a 5103 big enough to handle these medium duty cutters or should I drop back to a light duty? I am posting a picture of my tractor and some of the clearing job in the background. Most of the pines are behind the row of hardwood scrub.
