jd 5103 3 pt lift
   / jd 5103 3 pt lift #1
smithra9
john deere 5103
i have a jd 5103 and i am having trouble with my 3 pt lift. it will no longer raise all the way up with an attachment hooked up. i can raise levers all the way but attacment will only go about half way. i can raise the attachment by hand and it will finishing raising up but will go right back down to about half way.
any suggestions would be appreciated
   / jd 5103 3 pt lift #2
Is that one attachment in particular or all attachments?
Is the weight of the attachment within you lift capability.
Is your3pt relief activating?
   / jd 5103 3 pt lift
it is a bush hog and it has always picked it up until now. like i said it will pick up half way but that is all. never any problems in the past. i have a front end loader also and i have not had any problems with it either, so far....
   / jd 5103 3 pt lift #4
Install a hyd gage and see if you have the pressure.
2015 PETERBILT 367 SLEEPER (A52576)
2015 PETERBILT 367...
TORO MBTX 2500 STAND-ON CONCRETE BUGGY (A51406)
TORO MBTX 2500...
2015 PETERBILT 389 TRI-AXLE MID-ROOF SLEEPER (A52472)
2015 PETERBILT 389...
2014 Ford F-150 Pickup Truck, VIN # 1FTFW1CT4EKG42947 (A51572)
2014 Ford F-150...
20711 (A50323)
20711 (A50323)
Caterpillar 56in Excavator Bucket (A51691)
Caterpillar 56in...
