JD 5101E vs NH TD5050
   / JD 5101E vs NH TD5050 #1
peter_vii
Ontario
B2320N, JD5083E
Which one to get?
JD 5101E+563 loader for C$52K
or
NH TD5050+Stoll #8HDPM loader for C$49K
Both brand new, same 2 yr warranty, same 0% for 48 mths financing.
JD has wet clutch and power shuttle, and better ergonomics (I think).
NH has better pump (it has two) 26 GPM vs 22.5 GPM on JD and NH
has 5000lb 3pt lift vs 3000lbs on JD
Which one would you buy and why?
Thanks,
Peter
   / JD 5101E vs NH TD5050 #2
You picked a couple of pretty closely matched tractors there. I'm not a JD fan, but I would lean toward it if I was going to do a lot of work with the loader. Power shuttle has a real advantage in that respect. If I was going to do primarily work off the 3 pt I might lean toward the higher capacity on the NH, but I would suspect that the real world difference is not as great as the specs show.
Are both dealers good solid dealerships?
2007 PETERBILT PB335 LUBE TRUCK (A51243)
2007 PETERBILT...
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A49461)
2019 Generac...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
2019 Ford Fusion Sedan (A50324)
2019 Ford Fusion...
2015 Dodge 5500 4X4 Bucket Truck (A51039)
2015 Dodge 5500...
KUBOTA M7040 TRACTOR (A51406)
KUBOTA M7040...
