JD 5100e vehicle speed indicator does not function
   / JD 5100e vehicle speed indicator does not function #1
Dadnatron
Veteran Member
Versailles, KY
JD 5100e with FEL
JD 5100e
3yr old off lease at 400hrs. I've put about 800 on it myself.
When I purchased it, everything worked just fine. At some point about 5-6mo ago, I noticed the vehicle speed indicator was no longer functioning. It is based on a "Roll Mode Sequence Order" switch, with PTO and hours in the loop. Both of which work normally, so it isn't the dash. There are no codes showing. I have no other idiot lights. I'm stumped. The only thing I can think of is that I somehow lost/broke/dislodged the peripheral sensor so there is no reading. It shows, 0.0 mph at all times.
I've been trying to figure out where the peripheral sensor is located in order to see whether I have inadvertently dislodged it somehow. Otherwise, I am at a loss. I do not see a fuse specifically for MPH. I haven't contacted JD as of yet, because it has not been important. But with me looking to spray, I recognize it IS important for spraying, hence I need to quite ignoring the issue and get it fixed.
Any help would be appreciated.
JOHN DEERE 7210R LOT NUMBER 263 (A53084)
JOHN DEERE 7210R...
2017 FORD F150 REG CAB LONG BED 4X4 (A52577)
2017 FORD F150 REG...
Bobcat 3400 4x4 Utility Cart (A51691)
Bobcat 3400 4x4...
JOHN DEERE/UNVERFERTH 1700/330 (A53084)
JOHN...
Kubota SVL95-2 High Flow Cab Skid Steer (A53472)
Kubota SVL95-2...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A51573)
(1) HD 24ft Free...
