JD 5100E Clutch Shuts Off Electronics
   / JD 5100E Clutch Shuts Off Electronics #1
haytim
John Deere 5100E
Hey y’all. Got a new to me JD 5100E that every time you press the clutch pedal, the radio, blinkers and air ride seat shuts off. Issue only happens when the switch on the clutch at the end of the cycle is actuated. To be clear, the pedal doesn’t have to hit the metal backstop. Guessing it’s either a diode or something shorting out. Not sure where all to check. Any ideas would be appreciated!
Found the issue. The starter relay under the dash just above the clutch had one of the red wires turned to where when the clutch was pressed fully it would just barely put pressure on the connector. The connector was broken internally and the clutch would move it just enough to cause it to disconnect. Hope this helps someone else.
   / JD 5100E Clutch Shuts Off Electronics #3
Thanks for following up and letting us know what you found, that's rare around here, also congratulations on figuring it out.
Agco S150 Manure Spreader (A50774)
Agco S150 Manure...
SET OF SKID STEER QUICK ATTACH PALLET FORKS (A51243)
SET OF SKID STEER...
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
377811 (A48836)
377811 (A48836)
2021 MDB TF150R 84" HYD MULCHING HEAD (A51243)
2021 MDB TF150R...
