JD 5093 with a JD 457 Baler
   / JD 5093 with a JD 457 Baler #1
gcatz
JD 5093
I have a JD 5093. I also use a JD 457 baler to bale with. I am having problems getting my net wrap cut. I think it has something to do with the voltage but nobody can figure it out. If I hook my cables directly to the battery it will run it ok, but if I go through the cables it doesn't work. Any ideas?
   / JD 5093 with a JD 457 Baler #2
If I understand correctly... when you use the rear-mounted tractor coupler (7-pin..?) the wrap cutter doesn't function correctly, yes?
If you connect the leads from the baler to the tractor battery everything works; yes?
And you checked the pin-outs on the coupler with a volt-meter?
AKfish
Does your tractor manual list a pin-out for the coupler?
   / JD 5093 with a JD 457 Baler #3
To my knowledge all JD rd hay late model baler monitors are intended to be hooked to this AE50549 WIRING HARNESS which is referred to as a convenience outlet.
7 pin coupler is for warning lights
Thanks for the information. I will check this out. Thank you!
Swict 78" Bucket (A50121)
Swict 78" Bucket...
2006 Dodge Ram 3500 4x4 Pickup Truck (Diesel), VIN # 3D7LX38C36G220767 (A51572)
2006 Dodge Ram...
2013 Ford F-650 Truck (A51692)
2013 Ford F-650...
2007 International 4300 Box Truck, VIN # 1HTMMAAL27H513415 (A51572)
2007 International...
2012 Ford Expedition XLT 4x4 SUV (A50324)
2012 Ford...
New LS170 Skidloader (RUNS) (A50774)
New LS170...
