Jd 5085m pto and lift not working!
   / Jd 5085m pto and lift not working! #1
ajd4339
Kentucky
John Deere 5085M
My 2010 JD 5085m was last used rolling hay about a month ago everything worked fine. It's been setting for a month. Now the pto will not do anything the dash light don't even come on. And the lift wont go down. I do get the lift warning light on the dash. Any ideas on what could cause this?
   / Jd 5085m pto and lift not working! #2
No good ideas. Maybe someone will chime in. I'd be in touch with my dealer mechanics in the meantime.
   / Jd 5085m pto and lift not working! #3
Soo sounds like have eh controlled 3point as opposed to mechanical since the electrical issue also affects three point (they could have either style controls). I agree, get your dealer involved, check fuses, etc. See if op manual has a section for pulling codes for your visibility, although this machine may not have that capability.
Yes eh control. All fuses check good and pto switch is good. Guess I'll haul it to the dealer next week
Sony TV/ Polycom Unit and Stand (A50325)
Sony TV/ Polycom...
Hyster H225E (A47384)
GORBEL EASY ARM LIFTING ARM (A52472)
GORBEL EASY ARM...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
2013 FORD F-650 ROUSTABOUT TRUCK(INOPERABLE) (A52472)
2013 FORD F-650...
