JD 5085 E CAB
   / JD 5085 E CAB #1
bravo2zero
Alabama
Okie dokie... I am taking the plunge and purchasing a JD 5085 E in April, waiting on taxes. To be honest I'll have to wait a few months on the front end loader. However I will be purchasing a finishing mower for the 5085 E, so that I can get busy with the land.
Can anyone share their experiences with the mowers? I don't want a bush hog. I like to keep my land looking nice and clean. I do plan to HAY and that in itself is an entire different type of setup. For right, now I wanted to know what your thoughts are on the finishing mowers. I was thinking 12 ft, the wing type that fold up and down? Any horror stories about this type of rig?
And I was going to go with the 5075 E CAB but for a few thousand more I can upgrade to the 5085 E CAB. And tires was something I wanted to check on, considering I didn't want to tear up the land. I'll be mowing about 50 acres give or take a couple.
Thanks everyone.
   / JD 5085 E CAB #2
heres a peice of advice.but i dont know if it holds true for all jd tractors.but it costs $2000 or more or less to rig your tractor for fel.plus the cost of the fel.so if i was you id have the loader installed when you buy the tractor.as the loader an everything needed will most likely go up in a year.
   / JD 5085 E CAB
I see about 2,000 more if it has to be rigged up at a different time, rather than it not coming stock?
   / JD 5085 E CAB #4
Tires, is the 50 acres a lawn? If not be less worried about tearing up the ground and be more concerned about traction. If your mowing a lawn then I personally wouldn't use such a large machine. I'd be looking at a larger ztr. It would now much faster and better. Just my 2 cents worth.
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A55218)
2008 Ford F-250...
2002 Olympian D90P1 96kW Diesel Generator (A52377)
2002 Olympian...
2012 SOUTHERN 130BBL VACUUM TRAILER (A53843)
2012 SOUTHERN...
2017 Rockwood Esp Pop Up Camper (A51694)
2017 Rockwood Esp...
2012 Infiniti G25 Sedan (A55758)
2012 Infiniti G25...
