JD 5065e thermostat replacement
   / JD 5065e thermostat replacement #1
Rmd8136
Ft mill, sc
Deere 5065e MFWD
I was looking at my tractor yesterday and it appears there is a coolant bypass line from the block (just behind cooling fan) to the thermostat housing (on radiator side of thermostat). Is that correct? If so it looks like there is a 1/2" diameter pipe connection on the thermostat manifold. Does anyone know how the seal is made inside to prevent coolant leakage inside that thermostat housing? How would you remove that pipe? On the end toward the block (adjacent to cooling fan) it has a rubber hose clamp which would be easy to remove. Also, it appears this 1/2" diameter pipe is blocking access to one of the 2 hex head bolts that attach the thermostat housing. How get a wrench on that bolt? Any advice would be appreciated.
Thanks so much. Sounds straightforward. Still wondering how that bypass pipe seals inside the housing? I guess when you pull it out it will be self-explanatory. Thinking rotating the pipe to left side makes the jont pull in to seal; perhaps a quarter-turn thread.
   / JD 5065e thermostat replacement #4
If you go to JD parts (URL below) and look up thermostat cover you will see there is a rubber seal, that goes into the cover and the tube goes into that seal.
John Deere - Parts Catalog
Thanks very much
Porter Cable 20V Drill (A44391)
Porter Cable 20V...
New/Unused Self Dumping Hopper (A44391)
New/Unused Self...
2017 Ford F-150 XL (A44501)
2017 Ford F-150 XL...
YANMAR SV08-1A (A45333)
YANMAR SV08-1A...
2020 Ford Transit Van Van, VIN # 1FTBR1X82LKB60955 (A44391)
2020 Ford Transit...
2000 PETERBILT 379 (A45046)
2000 PETERBILT 379...
