JD 5065e Thermostat replacement?
   / JD 5065e Thermostat replacement? #1
Rmd8136
Ft mill, sc
Deere 5065e MFWD
Moved to JD Owning/Operating - Sorry
I was looking at my tractor yesterday and it appears there is a coolant bypass line from the block (just behind cooling fan) to the thermostat housing (on radiator side of thermostat). Is that correct? If so it looks like there is a 1/2" diameter pipe connection on the thermostat manifold. Does anyone know how the seal is made inside to prevent coolant leakage inside that thermostat housing? How would you remove that pipe? On the end toward the block (adjacent to cooling fan) it has a rubber hose clamp which would be easy to remove. Also, it appears this 1/2" diameter pipe is blocking access to one of the 2 hex head bolts that attach the thermostat housing. How get a wrench on that bolt? Any advice would be appreciated.
2025 Star EV Capella 2+2 Electric Golf Cart (A51694)
2025 Star EV...
2014 FORD F250 XL SUPER DUTY CREW CAB TRUCK (A51406)
2014 FORD F250 XL...
John Deere S780 Combine (A53342)
John Deere S780...
Pallet of (15) 10 Lug Misc Wheels (A51573)
Pallet of (15) 10...
2013 FREIGHTLINER CASCADIA SLEEPER (A52576)
2013 FREIGHTLINER...
NEW Ripper Shank (A53002)
NEW Ripper Shank...
