Rotary Cutter JD 506 rotary cutter's slip clutch missing
   / JD 506 rotary cutter's slip clutch missing #1
sweetgrassman
Helena, MT
JD 2940, 2649, 318
I just purchased a used 3 point, John Deere 506 rotary mower. After getting it home and reviewing the operators manual I noticed that it did not have the slip clutch assembly. The pto drive shaft attaches directly to the gear box and then down to the cutter blades. There is a shear pin assembly between the driveshaft and the gear box. I assume it was used in the past without the slip clutch. I plan to use the mower to cut grass on level ground used for hay and horse pasture. Is it OK to use the mower without the slip clutch? Sounds like a dumb question but thought I would ask.
Thank you
   / JD 506 rotary cutter's slip clutch missing #2
Yes it should be fine. I think most smaller mowers just use shear pins. Hopefully someone can give you the recommended size and grade in this thread. My 4' Chinese rotary mower uses a grade 2. Don't use stronger than necessary.
ADDED: This is a link to one site that sells parts. It looks like a 5/16 x 2" but does not specify the grade.
Error
2017 Ford F-150 Ext. Cab Pickup Truck (A50323)
2017 Ford F-150...
2013 VOLVO VNM TANDEM AXLE DAY CAB (A52141)
2013 VOLVO VNM...
2014 UTILITY 53X102 DRY VAN TRAILER (A52141)
2014 UTILITY...
KMC KELLEY 3374 PORTABLE PEANUT COMBINE (A51243)
KMC KELLEY 3374...
43018 (A51691)
43018 (A51691)
