coaldust
I have a 2013 JD 5045D with 71hrs on it. I started the tractor and let it idle to charge the battery, I went to check on it after approx 30 minutes and the tractor had died. I noticed a fuel leak from the rubber hose coming from the tank to the filter,
I replaced the hose and used a small 12v pump to push fuel from the tank forward. I bleed the fuel filter then opened the bleeder and fuel return line at the injector pump. (fuel flow good at the pump and out the return line, I tried starting the tractor and no luck), I then loosened the fuel lines at the injectors and no fuel came out so I removed the 2 fuel line I could get to on the injector pump and no fuel comes out of the pump. I did remove the 12V pump at the tank and reattached the hose to the fuel shut off valve.
Don't know if I messed up using the 12V pump to bleed the system but I definitely have screwed up something, I do have 12V power to the fuel shut off valve on the top of the pump.
Can anybody help me with this problem???
