gatornapper
- Joined
- Jan 10, 2010
- Messages
- 26
- Location
- Goochland, VA
- Tractor
- 2010 JD 5045E w/JD 553 Loader got new, had tractors since '82
Tractor like new, just over 400 hrs. I'm an electrical guy and normally solve such problems quickly. But this is unusual.
Solar panel keeping battery charged failed, battery very low.....engine would turn 1 or 2 revs, then battery dead.
Tried jumping from car. No change even tho I brought battery voltage up to 12.6+ volts. All battery connections are good. 13.6 volts from car & still only slow crank, then nothing.
On last attempt to crank, engine started to turn over as before, but this time, I heard something, and then no crank at all.....but still could hear solenoid click in.
Put strong charge on battery for couple hours. Battery fully charged, full voltage to all points on tractor but engine no longer turns over when I try to start it....just a very loud & strong click of starter solenoid.
When have key in start position, voltage at starter solenoid is 12.5 volts - indicating a.) battery is now strong; b.) starter is not getting voltage as starting voltage would be 12 or below when cranking.
Sounds like bad starter solenoid to me. Solenoid activating, but contacts burned or bad.
All fuses are good. Starter relay is good. I have schematic of similar JD starter circuit and have some questions: What is "Bypass Start Relay" and what does it do? Looks like it parallels the Start Relay and can also start the engine? Where is it?
TIA,
Gatornapper
Manakin, VA
TIA,
Gatornapper
Manakin, VA
