JD 494a planter help
   / JD 494a planter help #1
taxidermist1
Fowlerville Michigan
I need to know how long of a hydro cylinder is on the planter for raising and lowering the unit.What I need to know is Bore size, Stroke, center to center measurement.
Thank You,
Rob
   / JD 494a planter help #2
Standard 8" stroke agricultural hydraulic cylinder with one inch pins. 2.5" bore should lift it with a 2000 psi system. If the tractor has a lower pressure system, i would get a 3" bore cylinder to be safe if the planter has fertilizer hoppers.
2017 Ford F-150 4x4 Crew Cab Pickup Truck (A51692)
2017 Ford F-150...
FAE 150/540 LOT IDENTIFIER 72 (A53084)
FAE 150/540 LOT...
FRONTIER FAV20 LOT IDENTIFIER 42 (A53084)
FRONTIER FAV20 LOT...
UNUSED FUTURE FT-XJ7T 7 TON 46" HYD THUMB CLAMP (A51248)
UNUSED FUTURE...
UNUSED JCT 84" HYD ROCK GRAPPLE BUCKET (A51248)
UNUSED JCT 84" HYD...
BESTWAY AG VSK50 LOT IDENTIFIER 27 (A53084)
BESTWAY AG VSK50...
