JD 4700 Fender Replacement Questions
   / JD 4700 Fender Replacement Questions #1
swmich42
Bronze Member
Southwest Michigan
2000 John Deere 4700 4x4 Hydro
Need help with the fender the dealer installed on my 4700. There are two square holes, which do not appear to be required to mount to my chassis. Tractor was inside my pole barn, when the snow load collapsed the roof. Only significant damage was right rear fender. The first hole I described is next to where the rops attachment point secures the fender to the square ROPS bar. The second is inside the cavity which houses the cup holder. When I questioned whether this was the correct fender, I was told the hole by the ROPS area is from the factory. The other hole (inside cavity described) was created to prevent stress, due to misalignment on attachement points. I will take photo's this week and re-post. Any help is appreciated.
   / JD 4700 Fender Replacement Questions #2
JD parts shows Part number LVU11625 subs for LVU10633 so there might have been changes that also changed the part number
2003 Ford F-650 Flatbed Truck, VIN # 3FDNW65243MB03484 (A48836)
2003 Ford F-650...
1984 AM GENERAL HMMWV HUMVEE (A51222)
1984 AM GENERAL...
PENDING SELLER CONFIRMATIONS (A51222)
PENDING SELLER...
2023 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2023 PETERBILT 579...
Harper SB1300 Straw Blower with Hose (A51039)
Harper SB1300...
2024 Case IH Magnum 340AFS CVX Connect MFWD Tractor (A50657)
2024 Case IH...
